This is my Italian BeOne!! I love it!! So fast and confortable...
Component list:
Component Description (Manifacturer Model Size Notes) Weight (g)
Bar Ends: none 0
Bottle Cage: Exustar Carbon 18
Bottle Cage Bolts: Red Ergal bolts 2
Bottom Bracket: FSA Ceramic BB (Weight included in crankset) 0
Brake Levers: Formula R1 Carbon 530
Brakes Rear: Formula R1 with formula disc
Brakes Front: Formula R1 with formula disc
Cables / Housing: Alligator I-Link Black with powercordz 1.5mm cables 45
Cassette: Shimano XTR 11-34 244
Chain: Shimano XTR CN 7701 270
Crankset: FSA K-Force Lite 42-29 698
- Crank Arms: Original K-Force part
- Crank Bolts: Original K-Force part
- Outer Ring: Original K-Force part 42T
- Middle Ring: Original K-Force part 29T
- Inner Ring: none
- Ring Bolts: Original K-Force part
Derailleur Front: Sram RED road derailleur with BTP Carbon clamp 75
Derailleur Rear: SRAM X.0 20th anniversary with kcnc Black jockey wheels 184
Fork: Rock Shox SID 2009 1520
Frame: BeOne Black09 1002
Grips: Extralite 18
Handle Bar: Ritchey WCS Carbon 31.8 140
Headset: FSA Semi-Integrated 77
Headset Cap/Bolt: Carbon cap with red ergal bolt 6
Headset Spacers: Trigon Carbon 10mm + Bontager Carbon 10mm 6
Pedals: Crank Brothes Egg Beaters 4Ti 168
Quick Releases: Carbon-Ti X-Lock Red 55
Rear Shock: none 0
Seat: Tune SpeedNeedle Alcantara 88
Seat Binder: Carbon-Ti X-Clamp Red 14
Seat Post: Kcnc Ti-Pro-Lite 31,6mmx350mm with red supports 156
Shifters: SRAM X.0 Twister Shifters 173
Stem: Ritchey WCS 117
Tire Front: Schwalbe Racing Ralph 2.1 Evo 455
Tire Rear: Schwalbe Rocket Ron 2.1 Evo 391
Tubes: NoTubes Valves and Yellow tape 24
Wheel set (Front):
Wheel set (Rear):
Wheel Set (Entire): Custom Wheels Tune+ZTR Race+DT 1242
- Rims: NoTubes ZTR Race 32h
- Spokes: DT Revolution 2.0-1.5 32+32
- Nipples: Sapim Ergal Red
- Hub Front: Tune King Red 32h
- Hub Rear: Tune Kong Red 32h
Misc Option: Latex, lube, various 190
Total Weight 7908 Grams
17,43 Pounds
The real weight (weighted with an electronic scale) is 7,970 Kg!
Hope you like it!
